Rear sprockets-aluminum or steel?
Old Jan 17, 2002 | 02:30 PM
DRedd's Avatar
I have a '98 banshee and it is time to replace the chain and sprockets. I am getting a D.I.D. 520 ATV x-ring chain because it is supposed to last the longest. For the rear sprocket should I go with aluminum or steel? I know aluminum is lighter, but does it hold up as good? Will my chain outlast my rear sprocket?
Old Jan 17, 2002 | 04:31 PM
seven's Avatar
Whatever you do,Do not buy an aluminum sprocket.I went and spent the $$$ on a renthal top of the line and it lasted about 4 months of hard riding.My friend did the same and got about the same life out of his.Your best bet is to buy a stock or tell them you want the cheapest one they make.I have raced mx and flat track and the cheap ones hold up the best!!
Old Jan 17, 2002 | 04:40 PM
DRedd's Avatar
Hypothetically, if I buy aluminum (or steel) and it last for only 6 months would I then need to replace my chain also? The D.I.D. ATV x-ring chain is supposed to last for years, but would a 6 month old used one make a new sprocket wear out faster? What is the use of having such a good chain if you have to change it when the sprockets wear out if the sprockets don't last long?
Old Jan 20, 2002 | 01:17 PM
kukerdan's Avatar
why would you need to change the chain if the sprocket wore out?
Old Jan 20, 2002 | 08:16 PM
DRedd's Avatar
I have always heard that you need to change the sprockets and chain at the same time. Because if you just get new sprockets then your chain that is not new will wear out the new sprockets quick and vice versa.
Old Jan 20, 2002 | 09:39 PM
kukerdan's Avatar
never heard of that, makes no sense
Old Jan 20, 2002 | 11:32 PM
seven's Avatar
I will only replace both if i have run the chain about a year to a year and a half.
Old Jan 21, 2002 | 08:47 PM
atcfreak's Avatar
go for the steel because aluminum wear out to easy and no you dont have to replace your chain
Valder
Nov 28, 2020 07:38 AM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:57 PM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:48 PM
Jason Campbell
Sep 7, 2015 02:25 PM
black_thunder
Sep 7, 2015 01:24 AM
