side wall puncture??
Old Oct 15, 2002 | 12:21 AM
mster's Avatar
Default side wall puncture??
can a side wall puncture be pluggged? i have got a front and back tire on the warrior that got punctured,and was wondering, if i now need to replce them?, or if some one has plugged a side wall sucessfully.
thanks
Old Oct 15, 2002 | 10:31 AM
Team400EX's Avatar
Ive tried and failed miserable, its near impossible.
Team440ex
Old Oct 15, 2002 | 05:04 PM
Rudedog's Avatar
It depends on the size of the hole. Every tire place I've ever been (worked in a few also) say If it's a sidewall hole they won't fix it. There's just too much of a liability issue around it. IE: They fix it, someone goes flying down the road, turns, tire blow's out, person maimed or killed and a lawsuit follows as a result of them providing a faulty repair/service. Now can it be done, yes provided the hole isn't that large. There ususally patched and a tube is added as extra security. I've done a few for myself when I felt the circumstances were safe. IE: Tire used on a vehicle/situation where no life will be at risk and or very little weight or use. Like a wheel barrow or a car being restored as they typically just sit in garage, yard or driveway and are only rolled around. Tires for these types of cars are usually bald or inferior as who needs good tires to just roll something around. Later there usually replaced with good ones when the car is completed. The last one I repaired was on the rear of an ATC. This ATC only saw sand @ 2-4 MPH with only had about a 30Lb kid that rode it. So if the tires going to see normal action load/speed, I probably wouldn't have it fixed.
Rude Dog
Old Oct 15, 2002 | 06:34 PM
ftwflh's Avatar
I put 3 plugs in one hole on the front tire of my 4x4 and its been in all summer with no probblem.I put 6 in a guys Warrior and put silicone over it and it lasted all weekend and as far as i know he s still running it that way. By the way I do run sealant in my tires too and it helps when you plug tires.
Old Oct 16, 2002 | 02:48 AM
LT500duner's Avatar
I'm with Rude dog on this one. I repaired them the same way when I worked at a Goodyear tire shop, and we even had some "tire boots" that we used that is a special type of tire patch in conjunction with a tube.
Here's some key points:
If you aren't willing to accept all the responsibility for it not working or failing when you least expect it I'd buy a new tire or two.
Most generally for higher speed vehicles it's not recommended.
The more the sidewall flexes the less chance it will work.
Stiff sidewalls in low load low speed applications seem to work the best.
This means no jumping, hitting obstacles, or towing.
If it's just a thorn or small stick hole I'd show it to the tire person, but if it's larger I'd toss the tire.
hope this helps
Old Oct 27, 2002 | 03:44 PM
StevieD's Avatar
when i bought my 400EX used, it had Razrs, and the guy i bought it off of gave me the stock tires too. the front tire had a plug in it. it was a pretty big hole too. maybe i should see how well the patch works before i sell them.
[img]i/expressions/face-icon-small-cool.gif[/img]:
Old Oct 27, 2002 | 08:45 PM
warrior007's Avatar
Plug away!
I have 4 in my right front in just one hole. been that way all season. You guys are talking radial car tires, your right though they wont plug them in the sidewall on a car. They may patch em, depending on where they are. but when you plug a sidewall on a cars tire you have to ream and break the steel belt to get through, since it supports the weight of the car the steel belting will continue to fail and eventually blow out
but this is an atv, so plug... Im partial to the kit that pepboys sells, its 20$ but will last you a lifetime on atv riding, they are called camels and are the longest lasting plugs I have tried, the black tar ones at 7/11 wont last more than a month since they dry out.
Joe454
Nov 20, 2020 01:19 PM
Johnny Mac
60
Dec 14, 2019 06:13 PM
badgerboy1
Sep 26, 2017 06:11 PM
Dunes and Dune Machines
Sep 29, 2015 09:35 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
