Got a wheel spacer ???
Old Mar 24, 2003 | 11:41 AM
BLAZIN325TrailTank's Avatar
Default Got a wheel spacer ???
I got my new tires on the back but now when I try to slide or take a hard corner the tires seem to rub a little on the inside. I went from a stock AT21x10x8 to a 20x11x8 Razr and still using my stock steel wheels.
What size/thickness of wheel spacers should I get?
What price can be expected to pay for the spacers?
Shoud I use wheel spacers on the front or just flip the rims?
Can I filp them without the valve stems hitting the the disc brake rotors and calipers?
Old Mar 26, 2003 | 12:40 PM
Evidently no one has used wheel spacers on a Blaster before. [img]i/expressions/face-icon-small-mad.gif[/img] As many people that told me on this forum to go with the Razr's on the rear, Is mine the only Blaster made that the 20x11x8 rub on?
Old Apr 3, 2003 | 12:44 AM
Junior200's Avatar
You can not flip the front wheels on an 03 Blaster. Valve stem hits on the caliper. You will need wheel spacers or different wheels with a offset.
Old Apr 5, 2003 | 10:04 PM
Optic400's Avatar
u can flip them u just need to drill a hole on the other side and flip the other valve stem inside out, u can get smoe wheel spacers for $60 with rockymountain
Old Apr 23, 2003 | 11:03 PM
HiFlyinRaptorRyder's Avatar
If you do any big jumping then I would not recommend getting wheel spacers on the back because it will make it so much easier to bend the axle. If you do alol of jumping go with the axle for sure, either way, the axle is the better choice in the long run.
Old Apr 26, 2003 | 02:04 AM
I made a set of 1.25 inch spacers at work and I'm going to put them on saturday. Made out of aluminum, bolt them to hub then bolt whell to the spacer. $10 for the new studs and nuts.
badgerboy1
Sep 26, 2017 06:11 PM
Oct 10, 2015 10:20 AM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
tysonbully
Sep 28, 2015 02:30 AM
r1pilot83
Sep 27, 2015 07:38 PM
