Mudlites vs. Mudbugs
Old Mar 30, 2003 | 11:53 PM
WeAREsane's Avatar
Default Mudlites vs. Mudbugs
Well can someone please give me the facts about these two tires. They will be used for Trail riding, Snow, loose terrain, sand, and bog. Factors such as tread wear and ride quality are important. Thank You for all replies
Old Mar 30, 2003 | 11:54 PM
WeAREsane's Avatar
Sorry forgot to mention That these will be going on a 2003 Honda 450 S. Do you all think that this quad stock could handle 26" tires in its stock form?
Old Mar 31, 2003 | 12:05 AM
stubblejumper's Avatar
I have 26" gators on my rubicon with no problems with clearance or power loss.Since gators are almost identical to mudbugs there should not be a problem.I have only ridden them in snow so far but they ride well at all speeds above 5 mph or so and steer very good.Below 5mph or so on hard surfaces they are a little rough as are most aggressive tires.According to other people using them they also work very well in mud and tread life is quite good.
Old Apr 10, 2003 | 09:12 PM
danielbruton's Avatar
some people say the mudlites wear very fast. i would get the mudbugs or gators. they wear good and they look like they would give just about the same ride but better mudding capabilities. as for power loss, the mudlites would save the most power due to less rotational mass. however, all these tires are very light and almost the same weight. mudlites are the lightest, followed by mudbugs, then gators. if you go with mudbugs, you might want to go up to 27" because they are actually lighter than the 26s due to more void(space between the lugs) and the width of the lugs.
Old Apr 11, 2003 | 02:00 AM
swampdonkeykiller's Avatar
I have 26" Mudbugs on my '03 450ES and love them. So far they have been an excellent tire. They fit perfect. I would reccomend them to anyone who rides in Alberta.
Wolfaslov
Jun 2, 2002 02:01 AM
Wolfaslov
May 23, 2002 12:10 AM
Roofer
Jan 30, 2002 12:12 AM
rangerchet
Mar 23, 2001 11:32 AM
BearHunter
Dec 27, 2000 02:54 AM
