Dunes and Dune Machines Discussion on dunes and dune machines.
front dune tires
Old Jul 29, 2003 | 12:45 AM
Nailed's Avatar
Default front dune tires
The tire shop just mounted my gbc dune trackers with the sharp side of the rib on the out side. It looks wrong but I'm not sure that it is. In a turn the inside tire will slide and the outside will dig in. In theary don't you want the inside to bite? HELP We leave for Oregon this week, my time is running out.
Any help would be apprecated.
Old Jul 29, 2003 | 12:58 AM
DaSandBomb's Avatar
There on right, if the razor side is on the outside.
kc
Old Jul 29, 2003 | 01:22 AM
Treeshot's Avatar
If you take a sharp left turn the lateral force of the bike gets transfered to the right side of the quad making the tires on that side dig in. You want the straight side of your rib towards the outside of the quad for this reason. Having the straight edge on the inside of your tires wouldn't do much good because theres not enough weight on the inside tire through a turn to get much traction.
Old Jul 29, 2003 | 01:30 AM
Nailed's Avatar
Just like I thought, they were right all along. Thanks.........doesn't hurt to ask
Old Jul 29, 2003 | 09:27 AM
Treeshot's Avatar
You bet man, always glad to help out if I can.
Old Aug 1, 2003 | 02:37 AM
jsyi's Avatar
I took this quote from the STU website regarding the razorbacks "This biased rudder sand tire can be run forward or backward for more or less positive steering control."
Old Aug 1, 2003 | 07:15 PM
Sandfever's Avatar
If you want a little bit more responsiveness from your front tires in a turn, tap the front brakes when you are in the first half of your turn. With a little practice it makes a big diffrence.
Old Aug 5, 2003 | 03:49 AM
CroBiker's Avatar
hey, i'm lookin into gettin some razorbacks. do u notice a big difference in handling over knobbies?
Old Aug 5, 2003 | 09:46 AM
jsyi's Avatar
You can def tell a big diff. The first time i rode with razorbacks i took a turn like I normally would have and instead it ended pitching me over. straight tracking is a lot easier[img]i/expressions/face-icon-small-smile.gif[/img]
Old Aug 5, 2003 | 05:02 PM
CroBiker's Avatar
awesome, are there any tires that you would recommend? i was looking at the new sand stars and they seem like they would work the best.
