Dunes and Dune Machines Discussion on dunes and dune machines.
dune trackers: is bigger better?
Old Aug 7, 2003 | 01:00 AM
CroBiker's Avatar
Default dune trackers: is bigger better?
i have a 300EX and i'm looking for dune tires in front. i have the 20" sand shark paddles in back, and i'm wondering if i should go with 20" dune trackers in front, or would it be better/worse to get the 22"?
Old Aug 7, 2003 | 01:13 AM
wildchild660R's Avatar
I have 20 inch haulers in the rear and 22 inch shark fins in the front and everything seems to be workin out good for me.
Old Aug 7, 2003 | 01:59 AM
duneittilludie's Avatar
crobiker- i would get a front tire that is as wide as possible because a wider front tire with enough air pressure will help to float the front end out of the sand which means less resistance and drag and all of that translates into better performance.keep in mind that a taller tire in front will have a slight effect on how easy your front end will come up and by that i mean that because your back would be lower in relation to the front with a taller front tire you would be changing the angle your quad sits at on level ground.i personally prefer to set mine up with a tall front tire and a stock or slightly lower height in the rear but that is just my preference.
Old Aug 7, 2003 | 02:04 AM
sorry Off-Topic but hey duneittiludie when does honeyman stop lettin quads ride out of there place? Will it still be open labor day? Do they gotta # or website that you can contact them at?
Old Aug 7, 2003 | 02:05 AM
CroBiker's Avatar
ok, thanx for the info. i figured that the taller fronts would affect my wheelies but i don't usually drag so it shouldn't be a problem.
Old Aug 7, 2003 | 11:01 PM
wildchild660r- i dont stay at honeyman so i dont know about the camping situation but you could pm sandman 430 and ask him because he stays there quite a bit and would probably have the info you need.
Old Aug 7, 2003 | 11:53 PM
Ok I ll do that.
Old Aug 9, 2003 | 02:26 AM
TheSorb's Avatar
I like the 22" Dunetrackers, but then my DS is considerably larger than a 300EX.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Aug 9, 2003 | 02:30 AM
INSeaRChOFDUNez's Avatar
Q]I like the 22" Dunetrackers, but then my DS is considerably larger than a 300EX.[/quote]
Are you Braggin??
Old Aug 9, 2003 | 02:33 AM
TheSorb's Avatar
Good one![img]i/expressions/face-icon-small-cool.gif[/img]
Sep 29, 2015 09:35 AM
Irishman301
Sep 23, 2015 01:47 PM
Ridgebackguy86
Sep 19, 2015 12:48 PM
Bigtwin700
Sep 9, 2015 09:32 AM
Logan Collins
Sep 5, 2015 08:03 PM
