Building a dune machine
Well I should have $1000 coming too me. I plan on getting stage 2 hotcam, wb rev limiter, wb or ct racing exhaust, and douglas aluminum rims and paddles. ANything else i should get while i am at it???
The stage 2 cam might be too much unless you do head porting and raise compression. Too much cam without the complementary mods will be worse than stock. Check what the Hotcams guys say when you order.
stage 2 cam is bad for dunes. i have a stage 1 in my 400EX and i can climb any dune at pismo (i know, they rn't that big, but still...) in first gear w/o gettin a run at it. paddles r a must. razorbacks in front will be nice if u have the x-tra cash. pipe, re-jet, air filter, air box lid gone, nerf bars, and maybe an extended swing arm would have u set w/o usin all ur cash.
