Dunes and Dune Machines Discussion on dunes and dune machines.
BEST SAND DRAG TIRE
Old Jan 4, 2004 | 12:59 PM
  #21
DuneDevil's Avatar
Default BEST SAND DRAG TIRE
Originally posted by: EAB
A buddy of mine just got a set of 10 paddle haulers and they look stright across while the one on DaBeechMans bike look round. Is that just different brands? Is one better than the other or personal preference?
The width of the rim will make it a tall rounded tire, or flat square tire.
The drag racers usually use a 6 in wide rim, where duners usually go to a 8 to 10 inch wide rim.
DuneDevil
Old Jan 4, 2004 | 01:06 PM
  #22
madracing's Avatar
the reason UL are rounded is because there is less rubber there to hold the form the rim holds the sides in the only way the tire can expand is out (ballon effect)
Old Jan 4, 2004 | 01:10 PM
  #23
madracing's Avatar
97redbanshee i'm interested in the ul i need some for my 250r, will be making debut at galmis MLK day 105hp
Old Jan 6, 2004 | 06:17 PM
  #24
2fastforyall's Avatar
well it depend on what u want top speed or hella power
Old Jan 7, 2004 | 02:02 PM
  #25
DaBeechMan's Avatar
"hella power" creates top speed. You can hook up any amount of power with UL's and they will also give you the best top end also.
I cant think of any drag racer that runs a 6 inch wide wheel. We all run 8's and 9's
Old Jan 7, 2004 | 07:36 PM
  #26
Sheesnojoke's Avatar
Who sells the UL and what is the advantage/disadvantage of 20/21/22 inch tires?
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
rawbdiggity
Sep 7, 2015 12:05 PM
