Dunes and Dune Machines Discussion on dunes and dune machines.
changing paddle size tires???
Old Aug 17, 2004 | 12:05 PM
speeeedy's Avatar
Default changing paddle size tires???
i have 20-11-9 8 paddle tires {turbos} and am going to change to 22-11-10 8 paddle tires {skats} and am woundering if i will need to change my gearing for drag racing or if i should be ok with my stock gearing 14-37. thanks
Old Aug 17, 2004 | 07:27 PM
1BigDSRider's Avatar
Not sure how its going to effect your quad. But with mine when I went from a 20inch tall tire to a 22inch. I noticed that I was not getting the same low end grunt I once had. Stock gearing on a Ds is 16/40. Im now running a 15/42 combo with 22's. Its about equal to stock gearing with 20 tires.
Old Aug 17, 2004 | 08:04 PM
speeeedy's Avatar
thanks for the reply. i figured it might be like a truck when you go w/ bigger tires you loose a little bit of the get up and go. so i might just put my 13 back on the front. 14 is stock. i also figured a ds rider would chime in first. yall seem to know alot about your rides over in the ds forum.
Old Aug 18, 2004 | 05:31 PM
SickRider's Avatar
Yep I would put back on the 13 tooth.
Old Aug 18, 2004 | 05:32 PM
SickRider's Avatar
Old Aug 18, 2004 | 05:33 PM
SickRider's Avatar
Cool I learned how to post twice! You post it then you oress back and press post again.
Old Aug 18, 2004 | 07:29 PM
speeeedy's Avatar
COOL. once it cools down we will hit dumont again. i cant wait to try the skats. i hope they are better than my turbos!
Old Aug 18, 2004 | 11:51 PM
sportkc's Avatar
I am running 22-11-10 8 paddle haulers on my 2003 and have found 13/38 gearing works great.
Old Aug 18, 2004 | 11:57 PM
What skats are you getting or running speedy. Extremes, haulers, taller haulers, or edges??
Old Aug 19, 2004 | 02:29 PM
speeeedy's Avatar
8 paddle haulers. i got them in a close out deal from a local polaris dealer. how can u tell the differince between the haulers and extremes by just looking at them? the sales men there knows less than i do.
Bratman2
Aug 6, 2022 01:42 AM
Schneider
Jul 24, 2015 05:05 PM
Jul 24, 2015 11:57 AM
baysport
Jul 23, 2015 11:37 AM
rcappie4
Jul 18, 2015 07:51 AM
