Dunes and Dune Machines Discussion on dunes and dune machines.
Over Heating in the sand
Old Jan 27, 2005 | 10:39 AM
MichaelAZ's Avatar
Default Over Heating in the sand
What dunes are you riding at and what is the elevation ???? What about the elevation where you normally ride ?? A bike running that hot after a little riding is not normal and there isnt a bolt on made that will fix it.
Old Jan 27, 2005 | 02:13 PM
OutRacing's Avatar
Okay guys. I ride at all the dunes. But mostly Michigan cause they are the closest. Yes, I spent all this money to have a fast machine and want to run cheep gas cause I live in the boon docks and that is all I have access to here. I don't know my elevation, When I get to where I am going to be riding, I re-jet when I get there. My carb (a Doug Eichner Edelbrock Carb) is SUPER easy to re-jet. The only oil coolers that I see on e-bay for a 400ex are used stockers.
Old Jan 27, 2005 | 10:42 PM
FireFly's Avatar
use the aftermarket cooler with the stock one. I will mount below the stock one in front of the oil tank. We used one from autozone about 6"x 12". you have to cut your oil line and find fittings that will work. Fourstrke tech sells a kit for the 400ex.
Old Jan 28, 2005 | 10:50 AM
Duneaddict's Avatar
Race gas is a waste of $$ for you if your motor was set up to run pump gas... The ONLY thing high octane fuel does is deter or eliminate detonation in higher compression engines... It does NOT make them run any cooler.
SO, it depends on how your builder set up your engine... if it's not detonating, you don't need the good stuff.
Sand works the motor much harder than trail riding or dirt riding... when you work them harder, they'll generate more heat... laws of physics at work here.
THe best remedy for your problem is liquid cooling, but that's not happening on that machine.
My $.02
Old Jan 29, 2005 | 01:20 PM
  #15
smitty911's Avatar
Change to ALKY that will really keep it cool.
Smitty
Jeff Roper
Feb 1, 2022 11:48 AM
Sw00p
Sep 24, 2015 02:50 PM
black_thunder
Sep 20, 2015 10:21 PM
rawbdiggity
Sep 7, 2015 12:05 PM
