Dunes and Dune Machines Discussion on dunes and dune machines.
Plug question
Old May 14, 2005 | 11:22 PM
mastinson's Avatar
Default Plug question
Will just putting and idling around make your spark plug look like it has been run lean. My plug usually is tan but for the last week I have been riding my 3 year old around the yard every day in third gear just barely moving. would this make my plug appear white?
Old May 14, 2005 | 11:27 PM
maddog56's Avatar
If you are lean on the pilot circuit, it could. Try richening up your mixture with your a/f screw a little.
Old May 15, 2005 | 01:19 AM
mastinson's Avatar
I think I might of figured it out, I put some sea foam in it to get some water out of the gas and it could of affected the plug color.
Old May 15, 2005 | 01:38 AM
maddog56's Avatar
Thats definately a possibility, glad you got it figured out.
Old May 15, 2005 | 01:53 AM
mastinson's Avatar
You think that might do it? Also I put 89 in it and I have been running 87?
Old May 15, 2005 | 01:59 AM
maddog56's Avatar
I thought you were telling me you figured it out. I've never used anything like that, so I cant speak from experience on its effects on the engine.
As for the switch to 89 octane from 87, that shouldnt make any real difference.
Old May 15, 2005 | 09:54 PM
hondabuster's Avatar
There are so many additives in gas , that unless you do a plug chop correctly the spark plug color is basicly meaningless.
Octane has no effect on plug color.
If its running correctly, with no drivability symptoms...its jetted good.
Heres an article on jetting, and it has a list of symptoms for rich and lean.
jetting
SDR-II
Sep 29, 2015 01:06 AM
Big bousse
Sep 26, 2015 10:42 AM
Captjay
Jul 23, 2015 12:33 PM
chammerbeck
Jul 17, 2015 08:06 AM
D-Hagz
Jul 4, 2015 02:19 AM
