Dunes and Dune Machines Discussion on dunes and dune machines.
Invertor Or Gen??? Airing Down Tires!!!
Old Aug 15, 2005 | 04:45 PM
Seadog2's Avatar
Default Invertor Or Gen???
Need to air down in the sand or when I go to the snow, but what is the best way to air back up?? 6 to 8 tires are alot. 31 inch tires right now. Tent camp, no camper. Flatbed trailer w/ 2 tires or 4 place in winter w/ 4 tires.
Invertor w/ pancake compressor?? What wattage & what size comp??
Generator w/ Pancake Compressor?? Same questions
12Volt QuickAir 2 or 3? Which one ?? Can you use a 2nd hose extension (theres) w/ these, or do you have to make one?
Other suggestions????? [img]i/expressions/face-icon-small-confused.gif[/img]
Old Aug 15, 2005 | 06:21 PM
UBETRUN's Avatar
I have a 1KW inverter/charger and 2 deep cycle batteries in my enclosed trailer. It will easily run a small (2HP) pancake compressor long enough to air up 8 tires. I take a generator along for extended trips and plug it right into the inverter/charger which charges the batteries and feeds the trailer.
Old Aug 16, 2005 | 02:51 PM
Seadog2's Avatar
Default Invertor Or Gen??? Airing Down Tires!!!
Anybody have any experience w/ the QuickAir3 ??? [img]i/expressions/face-icon-small-happy.gif[/img]
Old Aug 17, 2005 | 12:04 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
I use a scuba tank. It holds 90 cubic feet of air at 2500-3000psi. It takes 1 to 2 minutes to go from 15psi to 45psi in one of my 31-10.5x15 tires.
Old Aug 17, 2005 | 12:17 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Forget all the other stuff. I messed around with a number of different methods, then I got a POWERTANK. Best solution I have found. You can air up a huge tire in seconds!
http://www.powertank.com/start.htm
Old Aug 19, 2005 | 12:14 AM
Teebone56's Avatar
I use the Quick Air 3 and am very happy with it. I air down to 20 lbs on my 265 70 17s takes 1 minute 15 seconds to air back up to 40 lbs. The trailer tires take 45 seconds to go from 20 to 40 lbs. It is light wieght and dosn't take up much space. It was a little spendy 500 bones but worth it. My 2 cents[img]i/expressions/face-icon-small-wink.gif[/img]
Old Aug 19, 2005 | 01:45 PM
Seadog2's Avatar
Thanks TB [img]i/expressions/face-icon-small-happy.gif[/img]
Ean
Aug 28, 2015 09:39 AM
suzukiquadrunner1987
Aug 6, 2015 03:59 PM
Jul 24, 2015 11:57 AM
baysport
Jul 23, 2015 11:37 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
