Dunes and Dune Machines Discussion on dunes and dune machines.
sand sharks or trackers
Old Feb 4, 2002 | 04:33 PM
discharge's Avatar
trying to decide which to get....are there any differences or just prices....i've got no clue about sand tires....
when they get mounted to the blades have to line up with the other tire
and is there much of a technique to sand riding
what rim should i run....i was thinking douglas .160
any others things i should now
this is for my banshee
thanks
Old Feb 5, 2002 | 05:25 PM
imadunatic's Avatar
it really depends on what type of riding you do, as far as the tires go, they're are both basically the same tire,
if you dont do any death defying leaps, the .160 should be fine,
it should help with the rolling inertia (having the lighter rims) because both styles of tires are pretty heavy for paddles, if you're just getting your feet wet on the whole sand duning thing, they should be fine, if you fall in love with it, you may find yourself investing in a set of higher priced/lighter tires,
but even the worst paddles are better than any all terrains in my book,
good luck, and where do you plan on riding?
Old Feb 5, 2002 | 05:57 PM
discharge's Avatar
theres a couple sand pits and sand mines here in NJ and would like to make a trip out to silver lake and later on glamis......maybe over christmas vacation next year....i've ridden with my bandits but i rather just have the sand tires....
also i was looking at www.sandtiresunlimited.com
saw a couple tires there.....i've heard alot of people say that the sand skate were for much higher horsepower quads....any incite on those....
thanks
Old Feb 5, 2002 | 06:01 PM
LT80's Avatar
LT80 Expert
Yes,when mounted they should be as close as possible to being strait across,it does make a diff.! Maybe you could check into the new maxxis paddles,,I love mine.Those that was behind me said that I threw more sand w/the maxxis than w/my haulers
Old Feb 6, 2002 | 05:33 PM
imadunatic's Avatar
the banshee is considered a "higher horsepower" quad, the sand skat 2's are nice, a little more money but all in all nice tires, the only thing you may want to stay away from (and this isn't from experience) is the taller haulers if your quad is mostly stock, they have a seriously tall paddle
my paddles are not mounted straight across from each other and they work great(22x11x10 8-paddle skat-trak edge on douglass .190), on the little bit of hard pack (50ft.) i have to ride across in order to enter the dunes, it shakes like crazy (cause they're not lined up) but in the sand they don't give perfect traction so when they're spinning (and they always are, regardless of what others will tell you, the paddles are designed to move cubic feet of sand) it doesn't matter, case in point, ive ordered 3 sets of paddles from rocky mountain, 2-haulers, and my edge's and none of them were lined up, this is from a company that sells hundreds or more sets a year, so i wouldnt worry about it, order the kit, bolt em on and have a blast,
Old Feb 7, 2002 | 10:34 AM
LT80's Avatar
LT80 Expert
dont need to be strait across eh,,,i'm going to glamis next week,,this will make for a excellent fire-side chat,im sure the guys will get a good laugh outa it! [img]i/expressions/face-icon-small-tongue.gif[/img]
Old Feb 7, 2002 | 05:42 PM
imadunatic's Avatar
check your PM.s and let me know the basis for this theory LT80
Old Feb 7, 2002 | 09:04 PM
discharge's Avatar
after searching the web and through magazines....i have decided on the kenda Gecko....only thing is what wheel size should i run....i was thinking an 8 to save weight and get douglas .160.....will an 8 even work on a banshee???
thanks for everyones help
Old Feb 7, 2002 | 09:27 PM
imadunatic's Avatar
yeah it will work, the only problem with the 8 in. is you get more sidewall flex (because there's more sidewall)
they should be fine though, let us know how you like the gecko's, pretty wicked looking paddle
Old Feb 11, 2002 | 06:51 PM
VEGAS650's Avatar
Gecko's may work fine in sand pits but take them to Glamis where the sand is very soft, they won't hook up very well. For optimum performance the blades should be lined up together but DON'T NEED to be.
