Dunes and Dune Machines Discussion on dunes and dune machines.
urgent help needed!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Apr 4, 2002 | 11:07 PM
thunderlizard's Avatar
how much oil does the zilla need to have in the crank case? i have put four liters in it, and it's still not up to the top of the cap?
Old Apr 5, 2002 | 12:28 AM
atc86r's Avatar
on my honda i have a screw in the side i remove and fill until it drips out.
Old Apr 5, 2002 | 09:29 PM
2fun's Avatar
There is NO oil in the crank-case for a quadzilla!
If you have put 4 liters in it already, there is something wrong!
The oil goes into the clutch/gear box.
For reference, a Banshee takes 1.6 qts. The quadzilla may take a little more, but not THAT much!
Where are you adding the oil?[img]i/expressions/face-icon-small-shocked.gif[/img]
Old Apr 6, 2002 | 12:52 AM
ZillaDaddy409's Avatar
[img]i/expressions/face-icon-small-shocked.gif[/img] For one thing you don't fill it to the cap,it's not a lawn mower.There's an inspection screw next to the water pump just to the left of it behind the back brake lever,remove it and add trans oil till it start's leaking from the hole,then replace the screw.1000ml or 1.06qt.
Sjrpp
Jul 5, 2015 09:04 PM
traumajunkie
Jul 5, 2015 03:03 PM
tweeder
Jul 5, 2015 01:57 PM
Mphillips
Jul 2, 2015 07:20 PM
