Dunes and Dune Machines Discussion on dunes and dune machines.
skat-trac edge vs. skat-trac hauler
Old Mar 7, 2003 | 04:10 PM
wildwildweb16's Avatar
Default skat-trac edge vs. skat-trac hauler
Which is better, the edge or the hauler. I have the skat trac edge and I know they are more expensive but does that mean that they are any better. What is the difference between the check style paddle and the straight paddle. Also, I am looking at getting dune fronts instead of using my stock tires for the dunes. What is the difference between the smooth and the fin style fronts?
Old Mar 7, 2003 | 04:44 PM
DaBeechMan's Avatar
mohawk's (or finned) tires seem to cut in the sand a little better then buffs. Buffs are lighter and still cut pretty decently. The straight paddles throw a good amount of dirt, i dont know what a checkered paddle is? The straight paddles are also going to make you go straight! they are a lot harder to swing the azz end out compared to the "v" paddles.
Old Mar 7, 2003 | 04:49 PM
So the only advantage to the v style is the turning ability? Mine seem to work great but I am just wondering if the straight ones are better or worse?
Old Mar 7, 2003 | 04:54 PM
DaBeechMan's Avatar
i guess it depends on what straight paddle your talking about. But generally yes. The v paddles seem to turn a lot easier then the straight cuts. Anybody else feel the same way?
Old Mar 7, 2003 | 04:59 PM
what style do you run dabeechman?
Old Mar 7, 2003 | 06:47 PM
DaBeechMan's Avatar
i run the straight paddle ultra lites on our drag bikes, and some set of v paddles on our duner. dont know the name or brand though. sorry. I know the ultra lites dont turn work a damn, and you'll never break the back end loose long enough to slide it out
Old Mar 7, 2003 | 08:12 PM
RodeHog's Avatar
wildwildweb you dont know what your takling about seriously
"v" are for < > like you
just teasing man
Old Mar 10, 2003 | 03:09 AM
ShackPol's Avatar
I've had both I prefer the straight paddles. They hook up alot better.
Old Mar 11, 2003 | 11:10 PM
Corpsie's Avatar
If I'm not concerned with sand drags and only racing around in the sand (I do more turns while in the sand that I do on trails) would you still recommend the straight paddles?
Old Mar 11, 2003 | 11:21 PM
OutOfControl's Avatar
No for all around riding get the V paddles.
