Best ATV Oil???
Old Jul 13, 2009 | 07:29 PM
BioWare's Avatar
Toxic Ryder
Mobil One MX4T Full Synthetic 10w-30
Old Jul 14, 2009 | 07:51 AM
TLC's Avatar
TLC
Higher reving stressed smaller motor have more benifits using synthetic oil the a big lazy truck motor would.
My old F 150 had 300,000 km with conventional oil and minimal oil changes, but that would not work out the same on a 450R or a 120hp 600cc rice rocket motorcycle I bet.
Old Jul 14, 2009 | 08:51 AM
scootergptx's Avatar
Supersock
Hired Gun!
With all the different types, grades and blends out there today, it's pretty safe to say the best oil out there is clean oil.
Best thing you can do, regardless of what you brand or blend you choose, is to change the oil and filter regularly.
Old Jul 15, 2009 | 01:09 PM
gumbyman's Avatar
amsoil makes good quality synthetic oils...but personal pref is what counts.... find one and stick to it....
Old Jul 16, 2009 | 12:02 PM
  #15
Beastly 3hundo's Avatar
I run Valvoline in all of my stuff, and I have no problems. Why spend alot of money to get an oil that has the same viscosity. I did a science fair project on this in 6th grade and found out that there isn't any real temp differance between conv. vs syn. (1-3 F). I did tests on an old Briggs and Strattor generator, and for each test I unplugged my house from the grid and powered it with the generator for about a half hour at a time. What's the point in spending alot of money on motor oil? There's no real difference.
Old Jul 17, 2009 | 12:25 AM
  #16
poolsean's Avatar
Anyone use car oil? I've read that it does work, as long as it doesn't have friction modifiers.
Old Jul 17, 2009 | 01:53 AM
  #17
TLC's Avatar
TLC
I used quaker state 10w-30 Automotive in my Big bear with no side effects.
Old Jul 17, 2009 | 06:16 AM
  #18
09 popo HO's Avatar
Does anyone have a link to a oil cross reference chart. I think alot of people could benifit from that.
Old Oct 20, 2009 | 10:48 PM
  #19
klondiker's Avatar
I asked the same question for the past two years and came up with the same answer: Maxima synthetic. My Honda Rubicon uses five quarts, a bit less, with the hydromatic transmission, so was concerned about what oil to use as the oil runs the transmission as well. The expense put me down to the next level, which was Amsoil 0W-40 synthetic and its been running fine for the past two years.
Old Apr 9, 2010 | 09:21 PM
  #20
SundiroSunray90's Avatar
i've had excellent luck with bombardier 2 cycle oil. the fully synthetic stuff. it works well.
