what causes gas to pour out of overflow on bottom of carb?
Old Oct 10, 2009 | 01:58 PM
Yamaharidah420's Avatar
Default what causes gas to pour out of overflow on bottom of carb?
im gettin ready to pull my carb jus wondering what im lookin for....
Probly a stuck float right? thanks
Old Oct 10, 2009 | 02:24 PM
TLC's Avatar
TLC
YouTube - how motorcycle and atv carbs work
Old Oct 11, 2009 | 11:01 AM
justme23005's Avatar
probably a piece of dirt in the needle valve. or bad needle valve.
Old Oct 11, 2009 | 07:42 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
float not set right, dirt under needle, bad needle or seat.
Old Oct 23, 2009 | 10:24 AM
sprayedgt's Avatar
99.9% of the time it's the o-ring that is on the needle valve assembly. It seals the top of the assembly from the bottom and makes the fuel only go through the opening in the valve. When it fails the fuel not only goes through the opening, but around the assembly, filling the bowl, overflowing into the head and out the vent.
Old Oct 24, 2009 | 06:06 AM
JeffinTD's Avatar
Float valve/seat failure, as mentioned above, is the most likely cause.
A blocked tank vent can allow fumes to build enough pressure in the tank to push gas past the float valve.
On some carbs that include a primer ****, the seal on the primer piston can deteriorate which will also result in the carb overflowing.
Old Oct 24, 2009 | 09:25 AM
tyler1blaster's Avatar
its the float.... most likely. if you do a wheelie and rest it on the grab bar you'll see gas drippin out..
GregM
Mar 6, 2018 06:53 AM
ghost civic
Jul 19, 2015 10:13 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Shifts
Jul 3, 2015 07:59 AM
