Can I run a smaller width tire.....easily.
Old Dec 8, 2009 | 02:39 AM
aaronrkelly's Avatar
Default Can I run a smaller width tire.....easily.
Will I have trouble mounting a 21x6-10 tire in place of a 21x7-10 tire. Found a REAL nice set of tires cheap on Craigslist.....but they arent the correct size. If it matter much its on the front of a Honda 200 Fourtrax.
Old Dec 8, 2009 | 05:56 AM
coyote170's Avatar
I think you will be ok,call a dealer close to you and ask him,or a tire shop
that handles atv tires.
Old Dec 8, 2009 | 10:33 AM
ss97's Avatar
Lets Ride!
Yeah you might have some problems, it depends on the tire...... The rims are 7" wide so technically you can run a wider tire, but running a smaller one might be a problem because the bead may not seal.
A 21x8x10 for example will work on a 21x7x10 rim, it will just bulge outside the rim more.
But I think a 21x6x10 might have a more narrow bead so it might work, or it might not seal well enough.....I think it all depends on the application. I think maybe in some brands that will work and maybe not in others......
Old Dec 17, 2009 | 11:56 PM
ddemetrius456's Avatar
Down grading will affect your car handling and braking, not by a huge margin.
___________________________
Designer Lingerie
caveeagle
Sep 19, 2015 01:20 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
toonces
Sep 5, 2015 01:14 PM
antiguogrumete
Sep 5, 2015 03:41 AM
bigred20653
Aug 31, 2015 12:41 PM
