Wheel Offset Question ?
Old Dec 14, 2009 | 02:48 PM
kfp673's Avatar
Default Wheel Offset Question ?
Hello All,
I am getting ready to purchase some wheels and tires for my 09 Yamaha Grizz 550. I love the machine however I would like to give it a wider stance for stability. I am pretty sold on ITP offset wheels and Maxxis Bighorn tires. From what I understand the ITP wheels will get me about 1 1/2" -2" in width. I have 2 questions. 1- Will this make a noticable difference? 2- Is it standard practice to run wheel spacers with offset wheels to get more width I read somehwere that spacers with offset wheels put extra strain on the drive train and hub etc. Is this the case or is this a standard practice. Your help is appreciated!
Old Dec 14, 2009 | 03:36 PM
mudslinginfool's Avatar
Does it in the Mud!
an offset rim is a good way to get stability for sure along with a 6 ply tire(like the bighorns). when you order your rims and tires make sure you tell them how many inches you want it to stick out from factory. They have different offset options. For example; 2-5,4-3,1-6. note: each two numbers equal 7,which is the total rim width. its up to you how much you want the rim to stick out on your atv. For you question, yes it makes a difference. i have offset rims with 28" swamplites and i am ALOT more stable on off camber situations. The down fall,im technically illegal to be riding Missouri trails as the max width is 50"(which is in most states). im at 52" but i usually ride private property anyways plus the 2" isnt that big a deal around here. You wont need wheel spacers if you get the width you want. i personally would not use wheel spacer,especialy if your buying new rims. if you use your stock rims then i would use them.hope this helps.
Old Dec 15, 2009 | 08:25 AM
KY RZR's Avatar
The standard offset on the itp wheels will give you a good noticeable and stable stance, so there is no need to run wheel spacers with them. The bighorn tires are probably the best tires on the market but keep in mind when you are buying them that they actually measure about an inch taller than what the tire height printed on the tire is.
Old Jan 9, 2010 | 07:41 PM
Kodiak450_06's Avatar
Originally Posted by kfp673
Hello All,
I have the ITP aluminum wheels on my Kodiak 450 and they are wider then stock. The rears stick out to far imo, but they get 300% much better traction, stability when rock climbing and going through mud. I got the ITP 589 tires with them. If we meet up tomorrow at RAC you'll see my ATV with the wheels.
Old Jan 9, 2010 | 10:47 PM
kfp673's Avatar
Sorry for the delayed response. I am crying in my beer watching the Eagles... Shoot me a message if you end up going tomorrow and I will try to catch up with you. Thanks!
Old Jan 10, 2010 | 09:31 AM
I saw you posted around 8am this morning, I slept to 9 today. Not sure if you went riding there or not, didn't get a PM from you with your cell number.
Old Jan 10, 2010 | 11:03 AM
nc porider's Avatar
Default wheel offset
just put new wheels on my 700 grizzly. The factory offset was 5+2 so to get a total of 2 more inches of width i went with 4+3 which is the same width you would get with 1 inch spacers so a rim with a 2+5 offset would do the same thing as 2.5 inch spacers. hope this helps
Old Jan 10, 2010 | 05:15 PM
nc porider's Avatar
Default offset
acutally the 2+5 would be like 3 inch spacers for a total of 6 inches over stock but that would probally be tough on the wheel bearings
Kyle5050
Dec 13, 2019 04:25 AM
Bergmann
Aug 13, 2015 03:51 PM
toonces
Aug 5, 2015 05:55 PM
Jul 21, 2015 03:03 PM
yambam13
Jul 4, 2015 01:49 PM
