Dream ATV.
Old Dec 31, 2009 | 06:39 AM
boomerdog's Avatar
Default Dream ATV.
OK folks I have been thinking a lot about what my dream ATV would be. The problem is no manufacture makes it. Since I work much more than play my dream is a little different I guess. It would have at least 500cc, have a solid rear axle, 2 inch receiver, a 5 speed with a real clutch. It would have a 3k winch installed at the factory, at least 100/200lbs rack capacity f/r. A minimum towing rating of 1100lbs, on the fly 4WD with front diff locker. It would also have front and rear tow hooks. Of course it would have to have a decent suspension so when I had the time to play I could. The list price should be in the $6500 range to. All this with good aftermarket support, like snow plow mounts, etc. So if this is what you wanted in an ATV what would you buy in this current market? Also please add what your dream ATV would be.
Old Dec 31, 2009 | 07:35 AM
smk8er's Avatar
sounds like you should buy a JEEP!!!
Old Dec 31, 2009 | 07:43 AM
DODGE57HEMI's Avatar
Mopar Man!
The closest thing you will find to what you want is a Kawasaki Brute Force 650.
2010 Brute ForceŽ 650 4x4 Sport Utility - Kawasaki.com
Old Dec 31, 2009 | 09:41 AM
boomerdog's Avatar
yep that is what I was thinking. It is the largest ATV that you can still get the solid axle. Just wish it had a non belted transmission.
Old Dec 31, 2009 | 09:43 AM
boomerdog's Avatar
Well I have a 1946 CJ2A that could do all the work I wanted to do but it is a little big for some of the trails I use to get to the food plots I work and stuff. Plus it is much harder to wrestle out of a mud hole if you don't have a good tree nearby.
Dunes and Dune Machines
Sep 29, 2015 09:35 AM
Lucas Bohanan
Sep 29, 2015 01:16 AM
tysonbully
Sep 28, 2015 02:30 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
awer1968
Sep 8, 2015 11:02 AM
