ATV tire repair ?
Old Jan 18, 2010 | 02:18 PM
blackjet84's Avatar
Unhappy ATV tire repair ?
so i had my Quad outside under the deck and i was going to ride it today but the tires were flat so i pumped them up but found out that 2 tires have cracks/hole in them, is there a quick/cheap way of getting it fixed ?
p.s. its not on the sidewall.
Old Jan 18, 2010 | 02:24 PM
scootergptx's Avatar
Supersock
Hired Gun!
For holes, I'd use a plug kit. If they're cracked from age, it's time to replace them.
Old Jan 18, 2010 | 03:01 PM
Same as above. If they are weather cracks replace them. If an actual puncture I had a slit in a sidewall that I put 3 plugs in and it held. Clean out the hole with a ream, put the plug in the tool, dowse it with glue, insert, turn 90 degrees and pull out the tool. Put in air. Check with a mix of water and a few drops of dish soap. If it is still leaking it will show up with bubbles blowing up and bursting.
Old Jan 18, 2010 | 11:30 PM
Rancher247's Avatar
If money's an issue you could probably find some stock tires someones taken off for free or pretty cheap.
Old Jan 19, 2010 | 04:18 AM
chuck_raduenz's Avatar
holes-get the plug kits
cracks-time to change the tire
many holes-tube
Old Jan 19, 2010 | 08:43 AM
DavidXP's Avatar
i use tire slime it messes up the balance but you never seem to get a flat in the trails......
Old Jan 19, 2010 | 03:51 PM
Sand Hog's Avatar
Default holes in tires
I just cut to the chase and put a tube in when the wife punched a hole through the new factory tire.
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
MooseHenden
Family ATVing Photos
Sep 20, 2015 04:14 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
black_thunder
Sep 7, 2015 01:24 AM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
