lift kit ??
Old Feb 13, 2010 | 06:25 PM
Daughtrylc's Avatar
Default lift kit ??
My bud has a Lift kit ?? After lifting the bike 2" the rear drive shaft u joint nuckle is hitting togther just a little. After riding u can see the marks. I know its from the angle from lifting it. The ? is cant I grind a hair off to keep it from hitting??
This is the nuckle coming out of the trans going to the rearend.
Old Feb 14, 2010 | 12:09 PM
Daughtrylc's Avatar
Anyone???????????????
Old Feb 25, 2010 | 02:08 AM
Daughtrylc's Avatar
Anyone????????????????????????
Old Feb 25, 2010 | 09:51 PM
matstang's Avatar
I'm no pro on ATV's but I know that you can get your drive shafts balanced on vehicles. I wonder if you do grind a hair off where they are hitting, will it affect the balance at all? And if so, can a wheeler shaft be balanced? That would be the question I'd have. If it's such a small amount to be ground, maybe the balance won't even be an issue? Sounds like it's going to have to be a trial and error thing. Worst comes to worst, it might be best to go back to stock...or reduce the amount of lift to reduce drive shaft angle. Sorry I'm not much help!
Old Feb 25, 2010 | 10:57 PM
wheily's Avatar
i did it on my truck when it was lifted but it was a front drive shaft can tell if it vibrates offroad. but as long as you dont take off to much that it weakins it you should be find .. with it hitting to gether and a little frame flex might over stres it and snap it... jmo..
QuadRiders
Oct 22, 2015 04:13 PM
Cantbuytime
Aug 17, 2015 06:33 PM
Cantbuytime
Aug 16, 2015 09:13 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
