"My 1st Rookie Mistake!...HELP!!!"...
Old Apr 21, 2010 | 11:17 PM
  #21
uncle matt's Avatar
Check your oil too. If you were running it around ultra-rich you want to make sure no excess fuel got into the crankcase to dilute the oil. Don't take a chance.
And next time you might want to pay attention to the smell of your exhaust. I imagine that thing had a pretty rich smell to it riding with the choke on.
Old Apr 23, 2010 | 07:20 PM
  #22
MiNuS...'s Avatar
I took it to the shop after all this happend...what happened was I was riding with the choke on for too long...it flooded the engine...I changed the spark plug and it fucked up again...come to find out...the gas or oil...I forgot what he said...but one of them or they could of mixed...but I don't know...but one of the two liquids was soaking with the air filter...so they had to clean it out and put in a new spark plug and new air filter...runs great now...I now know what the choke is for and how to use it...
Old Apr 26, 2010 | 04:00 PM
  #23
Sand Hog's Avatar
Default Rookie Mistake
Don't know if your engine has this..Some bikes have a "Primer Setting" on their fuel switch. If you have to prime the engine make sure to never run the bike in the primer mode unless your starting it, as soon as it starts turn it over to the run position or you will flood out your engine all over again..I have seen that happen to many times and it is a very costly mistake that you will only make once.
black_thunder
Sep 7, 2015 01:24 AM
Nazz26
Jul 30, 2015 11:51 AM
hondarider1234
Jul 21, 2015 11:53 PM
