Parking Brake Q
Old Apr 1, 2010 | 07:46 PM
PBLsQuad450's Avatar
Default Parking Brake Q
Hey all,
Noobie question, and I have a lot of them... When my quad is parked in the garage I have been leaving the parking brake on. Does this cause any additional wear to the breaking system? I could just find a chock, the floor is close to level (as a garage floor is) so it is not a big deal. Do you keep the rear brake pulled and clipped?
Thanks and glad to have a place to ask my noobie questions!
Old Apr 1, 2010 | 08:18 PM
mudslinginfool's Avatar
Does it in the Mud!
i just leave it in neutral. its not going anywhere without the brake on. could possibly bleed off as time goes on. The pressure of the brake fluid is pushing against some rubber seals that could weaken releasing the preasure,but they may not too.
Old Apr 1, 2010 | 09:40 PM
coyote170's Avatar
X2,good advice!
Old Apr 1, 2010 | 10:41 PM
Bfoughty's Avatar
X3
Old Apr 2, 2010 | 08:06 AM
If it's not rolling when in neutral I'd leave it out of gear and no parking brake. If your quad has a park position in the transmission I'd put it in park. If on a trailer or any slope I'd use both the parking brake and the park position in the tranny. Just my .02 worth.
Old Apr 2, 2010 | 09:06 AM
DODGE57HEMI's Avatar
Mopar Man!
My quad only has a park position to give you an idea of what some MFG think of parking brakes on the lever!
Old Apr 2, 2010 | 06:16 PM
aaronrkelly's Avatar
I leave mine in neutral in the garage so I can easily push it around and move it. All my parking brakes are cable actuated....so I dont see a wear issue. None the less I see no reason to use them on flat ground. Even on the trail I just turn the quad off and leave it in 1st gear.....never had one roll away.
Parking brake only gets used when trailering......JUST in case.
Old Apr 2, 2010 | 06:32 PM
Default Thanks
All,
Thanks for your comments! It isn't rolling with the parking brake off at all so I'll just leave it that way.
Old Apr 3, 2010 | 02:22 PM
One thing I've noticed at least with PoPos is that the single lever system that brakes both front and rear makes a fantastic parking brake. I've never been able to get a PoPo to move with a parking brake on. All the two lever brake systems I've been on could be pushed with the rear only parking brakes.
Old Apr 3, 2010 | 03:13 PM
That has to be a serious issue when hauling, even strapped in nice and tight? The Polaris atvs have single levers? We don't have a dealer anywhere near me so I didn't check them out, just looked at the "big 4." Where is the single lever? Do you have a foot operated brake?
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
Ahtatu
Sep 28, 2015 12:14 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
