Resealing a stell gas tank
Old Jun 13, 2010 | 12:02 AM
uncle matt's Avatar
Default Resealing a stell gas tank
I have a gas tank from a street bike. Inside the tank it basically looks like whatever factory film was in there is sheeting and flaking off. It is a 1978 Suzuki GS750. A local radiator shop quoyted me $80 on the phone to clean the inside. Then I could do a reseal or they could do it for additonal money. Well when they saw the tank they said it would need 3 or 4 cleaning treatments - not just one. Wanted $240 and there is no guarantee the paint won't be damaged.
There's a sweet sunset red over gold metallic paint job on there I don't want ruined. This is one of my old bikes from my younger days and the whole project has some sentimental value to me. I've pretty much gone thru all the mechanicals and fired her up after about 15 years of sitting.
So who has cleaned them out themselves? I am leaning towards a couple pounds of drywall screws and BBs in the tank, wrap the tank up in something like a sleeping bag and securely tape and tumble in the dryer with no heat. Probobly several steps, filtering out the chips from my "media" in between.
Then reseal it.
I want a good end result because I definately don't want to have to repeatedly pull the jets and clean out the carbs because stuff is coming from the tank.
Maybe adding a screen type fuel filter wouldn't be a bad idea either atleast for awhile after the tank is put back in service.
Old Jun 15, 2010 | 07:44 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
I'd check with your local bodyshop and see if they would give you a couple pounds of media blasting *****. And your idea of running a filter afterward? I won't run anything without a filter. Just a little insurance IMO.
Old Jun 18, 2010 | 11:45 AM
Dirtjunkie85's Avatar
I had a old 200s Honda three Wheeler that had sat for years the tank was full of rust so I tried this stuff and it worked great!! I would also recommend using the BB'S idea you mentioned along with this item check it out. tank repair
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
