Ultimate trail fix-all?
Old Oct 29, 2010 | 10:07 AM
kevin773's Avatar
how does jb weld work? does it harden or something?
Old Oct 29, 2010 | 02:40 PM
draarong2004's Avatar
its a very hard epoxy, you can actually drill it with a drillbit once its hardened, its as hard as steel once it cures, and depending on what type you get, it'll withstand up to 300 degrese or more, and it cures fairly quickly(depending on which one you get), the longer the cure, the higher the temp it'll take though to my knowledge.
I just used some to fix my engine casing on my warrior, but still need to get more on, didn't cover the whole area(found out when i took it for a spin and seen some oil coming out still, should patch it up after this time though). i know the stuff works, i know people that've used it on car engines and it held for YEARS...
Old Oct 29, 2010 | 06:51 PM
Mehoe's Avatar
Zip Ties are amazing. Duct Tape is good too. When I go on long rides I leave the tools at home and bring a few rolls of Duct Tape and a big bag of Zip Ties all sizes. LOL No really I bring Zip Ties and a set of tools.
Old Oct 29, 2010 | 08:44 PM
kevin773's Avatar
Nice! I like zip ties personally, but I will have to try that Jb weld stuff, sounds pretty awesome!
Old Oct 30, 2010 | 08:07 PM
  #15
user493's Avatar
Moto Psycho
Besides duct tape and zip ties, I found a few good uses for black iron wire that they use for tieing rebar. You can twist it a lot more than other wire before it breaks. One of my friends used it to hold an a arm together. If I have broken plastic I use pop rivets and pipe strap (after I get home) instead of just taping it.
Old Nov 4, 2010 | 09:34 AM
  #16
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
neither- although I do carry some 3' x 1/2" zip ties in my tool kit (got them from a utility company.)
The best thing to have is a small spool of 16ga steel wire-
I'm not a big fan of duct tape- I hate scraping off the glue and I dont trust it in moist / oily conditions.
I always thought jb weld took at least 24 hours to fully cure- that's no quick fix!
Old Nov 4, 2010 | 10:08 AM
  #17
kevin773's Avatar
Haha! I have indeed used wire before... We were in teh dunes and I snapped my flag off withing a few hours of getting there. I think we added several pounds to my raptor just with the duct tape and wire that we used to get it to stay back on!
Old Nov 5, 2010 | 12:05 AM
  #18
different degrese of jb weld available, the best ones do take longer, but like i said, there are 5 minute "marine use" jb welds available u can use on metals and such and it does a pretty good job of holding a seal till u can permanently fix it
Old Nov 5, 2010 | 08:58 AM
  #19
TLC's Avatar
TLC
Ever do a quick fix on the trail to get someone back home,then next ride out the quick fix is still there because they decided it was a permanent fix?
Old Nov 6, 2010 | 11:23 PM
  #20
Dyla g's Avatar
no question zip ties. they come in different size, and can be formed to do about anything
