Push mower into Pull behind mower
Old Nov 8, 2010 | 12:25 PM
unit6666's Avatar
Default Push mower into Pull behind mower
Have any of you guys been crafty or lazy enough to rig up a Push lawn mower to pull behind your wheeler... I mean I know you can buy the tow behind mowers but they cost an arm and a leg... I was thinking about getting 2 push mowers welding them together and making a tow bar... I dunno i'm just sooo bored I NEED TO CREATE!!!!!!!!!!!!!!!!!!!!
Old Nov 8, 2010 | 01:52 PM
wheily's Avatar
my grandfather just took front wheels off and mounted the handle there and tieg it to rear grab bar on his forman
Old Nov 8, 2010 | 01:59 PM
unit6666's Avatar
I was thinkin that but i wanted something that looked a bit more like a finished product.. i also wanted to maybe put some bigger wheels on it also for rougher terrain..
Old Nov 20, 2010 | 06:39 PM
draarong2004's Avatar
i recomend using 3 unless you want that strip of grass between the 2.....might as well while your at it, could prolly rig something up that only uses one motor too, unless you wanna spend an arm and a leg on gas, using a belt system just like the big mowers
Old Nov 20, 2010 | 06:55 PM
Jaster94's Avatar
probably just take a lawn tractor mow board, at least a 42", mount a B&S 6 hp on top and let the belts do the work, mount 360° 4" casters from harbor freight for the 4" wheels and hard tongue the hitch to the quad. that way it's a tow behind but not at the whim of lag. can pull forwards and backwards and manipulate the mow board like a brush hog. do what you want.
Cummins Driver
Sep 11, 2019 01:22 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
sara durrant
Jul 6, 2015 05:32 PM
