Transmission
Old Mar 25, 2012 | 01:48 AM
whitelightning22250's Avatar
Default Transmission
Is Honda the only wheeler that doesn't use a belt driven clutch? I am just curious because I just had to replace another belt on my polaris. Not really wanting to change brands, but just curious. Thanks for your time
Old Mar 25, 2012 | 09:23 AM
Jaster94's Avatar
how old was the belt? are your sheaves worn and prematurely wearing it out? i believe yamaha still has some models with a centrifugal clutch along with honda. don't know about other brands.
Old Mar 25, 2012 | 09:42 AM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
honda's still holding on to their cvt-less tranny
you didn't give any details about your polaris so- can't comment on you breaking the belt.
Old Mar 25, 2012 | 10:04 AM
I have a 2001 Sportsman 500 DUSE. The belt had around 2300 miles on it. A honda buddy and I were playing around in some pretty deep water a few weeks back and i swamped the clutch. Pulled the cover off, changed belt, blew out black dust and installed new seal and a nice bead of silicon around the cover. Runs like a champ now! Should be good till the next time the water gets a bit too deep lol. Thanks again
Old Mar 25, 2012 | 11:37 AM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
we usually get pretty wet atving around new england- I've sunk my 06 sportsman 800 so many times up to the seat in mud & water- I lost count, as well as my outtlanders & renegade- I've never had a busted belt, had a belt slip or any other cvt issues. (actually- my 05 & 06 brutforce 750's had crappy cvt reliability)
if your cvt is slipping after you go through a little water, there's another problem- maybe water getting in around the cvt breather or something.
Attached Thumbnails Transmission-100_2417.jpg   Transmission-100_2410.jpg   Transmission-picture1.php.jpg   Transmission-212.jpg
Old Mar 25, 2012 | 12:07 PM
TLC's Avatar
TLC
Yamaha 400 Big bears and Suzuki 400 Eiger/KQ still have shifter trannys.
2300 miles out of a belt that only cost $80 and is easy to change does not seem bad.
Snowmobiles are my first sport, I figure if a belt can handle my sled with 800cc and 160 hp then they do not even really work hard on a ATV.
Old Mar 25, 2012 | 12:29 PM
Thanks for your feedback fellas. I think it should be fine now. The old belt that i took off wasn't even close to as reinforced as my new one. Im hoping the extra bead of silicone helps keep the water out. I think the reason the water got in was because the wheeler died when the water was seat deep. Other than an easy belt change, Im really liking my purchase of the polaris!
Old Mar 25, 2012 | 12:39 PM
irinman2424's Avatar
be cautious if your in deep water and you allow it to stall out it can suck water back in through the exhaust and lock the piston (aqualock) when I am in water I feather the throttle to keep it running so it dont suck water in through the tailpipe
Old Mar 25, 2012 | 12:45 PM
Have any of you guys added a drain plug to the bottom of the clutch cover? I thought of doing that so i dont have to pull the cover off to drain water next time
Old Mar 25, 2012 | 12:55 PM
on mine (newer than yours) has a red drain plug in it already from the factory it sits to the rear of the machine on the cover
