2010 Sprtsman 850 XP
Old May 28, 2012 | 08:14 PM
Jared Roach's Avatar
Default 2010 Sprtsman 850 XP
My 2010 sportsman only has about 60miles on it and standing from behind, the chassis sits a little to the left, any ideas on what is causing this?
Old May 29, 2012 | 12:08 PM
Did you check to see if the rear shocks are set on the same spot adjustment-wise? There are usually 5 notches in the adjuster.
Old May 30, 2012 | 08:12 AM
Yes they are set the same, I noticed the lean after the first day of riding it hard through the trails
Old May 30, 2012 | 08:31 AM
Maybe a leak in one of the tires?
Old Jun 16, 2012 | 12:13 PM
It seems to be working itself out and getting better each time i ride it, it only has 17hrs on it so maybe its just part of the breaking in stage lol, thanks for your input
Old Jun 16, 2012 | 12:30 PM
The other thought I had would be if the fuel tank on the XP isn't centered in the chassis there will be more of a lean to the tank side when it's full than when it's nearing empty.
Old Jun 16, 2012 | 02:09 PM
thats a good idea, ill check it out next time its near empty, Im getting ready to change the oil now, I dont need to prime the oil pump afterwards do I?
Old Jun 16, 2012 | 04:13 PM
Not sure on the XP.
Old Jun 16, 2012 | 04:33 PM
well just my luck, when I put the plug back in it wouldnt tighten and now it wont come out, So much for riding tomorrow
Old Jun 16, 2012 | 05:37 PM
Ugghhh...
speedbuff
13
Nov 11, 2020 10:16 AM
EIF
Apr 20, 2017 07:15 PM
WilliamBos
Sep 22, 2015 04:07 PM
switzomatic
Aug 24, 2015 12:57 PM
Gtsordo
Jul 22, 2015 01:27 PM
