85 Trailboss, no spark
Old Mar 3, 2013 | 06:49 PM
PredatorBasher's Avatar
Default 85 Trailboss, no spark
I just rebuilt the motor in my trailboss only to find that it now doesnt make any spark(it did a few months ago when I pulled the motor). There is voltage coming from the stator and from the cdi box, and i just replaced the coil but still no spark. It reads about 100 V from the cdi box. Is this enough voltage? Also, instead of pulsing voltage as the engine turns over, voltage from the cdi hits 100V then slowly falls. Isn't a sudden cutoff of electricity required to produce a spark?
Old Mar 3, 2013 | 07:32 PM
Since you replaced the coil the only tests I have are resistance checks for the exciter coil and the main stator. On the exciter coil check the Brown/White wire to the White wire leading from the stator to the cdi. Should be 120 ohms + or - 20% The main stator Black/Red to Brown White wire should be 20 ohms + or- 20%. If the cdi has a single black wire (kill wire) disconnect it and see if you have spark. If the exciter and stator check out,then it's possibly a cdi problem. Look under your model under "Magneto". Browse
Old Mar 11, 2013 | 03:36 PM
I was finally able to check the resistance( Had to get a new Multimeter.) The exciter coil was about 118 ohms, but the main stator seems to be toasted at 138 ohms. Can replace just the stator, or do I have to get a whole magneto?
Old Mar 11, 2013 | 04:31 PM
Parts breakdown show # 3083638 as the main stator (separate from the exciter coil) Hard to find for this model,but you might try Ricky Stator(give em a call with this part #) OR you can also try Ricks Stators. Ricky Stator
Old Mar 19, 2013 | 07:23 PM
I've done a lot of looking around, and have only been able to find used ones on ebay. Is it possible to repair the stator?
Old Mar 19, 2013 | 07:39 PM
If Ricky Stator or Ricks can't help and if the stator is NLA at any Polaris dealer then some generator/alternator shops (if any are close to you) may be able to help on rewinding/repairing any breaks in the wiring. Tough sometimes on finding parts for a 28 year old machine! Later model ones (say around a 90 model or so "IF" they are still available) might work,but you'd have to splice in your connector and no guarantee that it would work.
Old Aug 6, 2014 | 08:11 PM
I just got back into working on this trailboss, i still cant figure out this problem with the spark. Im reading about 30V ac out of the magneto, which is converted to roughly 100v by the cdi box. Since i last posted i have replaced the cdi box and the stator. I am still getting a constant voltage from the cdi box and the coil (no pulsing). If i ground the coil I am unable to register voltage anywhere. This seems odd, is there any sort of a wiring diagram i could reference, i am unable to find one?
pgamboa
Dec 24, 2023 11:52 AM
fordfaithful21
Dec 7, 2015 05:52 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
