Hose got lose and burned/gas leak/not starting
Old Mar 21, 2013 | 08:12 PM
b1sa's Avatar
Default Hose got lose and burned/gas leak/not starting
Hi guys started riding my first atv its a chinese so have no idea about the specs atc hoping you all can help. anyways back to the point A hose that is just under the choke switch ( not the gas hose cause this is on the other side with the filter attached fine) came lose and got burn at the end when the hose is lower gas is coming out of it and i have no idea where it goes there is a space that looks like it belongs there but its above the choke switch where the air intake and gas hose leads to... anyone has a simple diagram that would help with where this hose may belong and as well gas is leaking from alot of places including the air filter and its not starting please advise me as to what to do please........................................your guidance will be much
will post pics on request but there is a pic of my atv in my albums if anyone would like to know more please ask
Old Mar 22, 2013 | 12:58 AM
mudmike's Avatar
You may find someone who can identify that quad in the chinese forum (my usual hangout even though all I own are honda 3 wheelers now) just mouse over where it says forums, select brand discussion, then chinese quads. I couldn't tell a kazuma from a tau tau but they are 99% the same parts.
I would have to see a pic of the hose to know which you are talking about. The only hoses I can think having gas pour out are the main fuel line (you said it's not) the overflow/drain coming straight out the bottom of the carb (has a screw right above it you use to drain the carb make sure this is snug) or sometimes there is a vent line on the side of the carb. The last 2 just hang free at one end but neither should pour fuel unless your carb is dirty.
The gas pouring out the air filter could be from a dirty carb or a vacuum leak.
Old Mar 22, 2013 | 07:57 AM
b1sa's Avatar
You all are truly life savers... i have a much better idea now i feel you're right about the carb being dirty i will post pics of everything in the chinese section by tonight please look out for them. And thank you soo much
Hankey Pankey
26
Oct 18, 2020 03:50 PM
Ty Speece
Jul 2, 2015 04:59 PM
Dabears1983
Jun 16, 2015 12:17 PM
1000gade
May 27, 2015 12:37 PM
