eton viper 50cc no spark
Old 07-11-2014, 06:05 PM
kasius's Avatar
Default eton viper 50cc no spark
I picked up a little Eton viper mini 50cc. I don't know much about them, it does turn over but I can't get a spark on it. I've changed oil and gas. Put new spark plug, ignition coil, cdi box, and stator. Still no spark. Any suggestions would be appreciated.
Old 07-11-2014, 06:47 PM
Jaster94's Avatar
double check your quick connects in the wiring harness/loom as sometimes the blades can recess themselves and not make good contact. i presume your red slider kill switch is working correctly? you may need to use your ohm meter/voltmeter to check that out. also double check your wiring on your keyed ignition.
Old 07-11-2014, 07:31 PM
kasius's Avatar
I checked the wire connections they all seem to have good contact. The slider kill does work. How would I test to see if the ignition switch is good?
Old 07-12-2014, 12:49 AM
Jaster94's Avatar
with switch "ON", you shouldn't show any going to ground.
Ramman1
08-11-2022 01:53 PM
Jr Wagner
08-21-2015 07:56 PM
BigT137
3) General Discussions..
08-19-2015 12:09 AM
mbkirk
08-14-2015 08:20 PM
mbkirk
Technical and How-To Articles
08-14-2015 08:12 PM
Quick Reply: eton viper 50cc no spark
