HPD contact info?
Old Apr 4, 2015 | 12:09 PM
Size_Matters's Avatar
Default HPD contact info?
I have a 2001 Polaris Sportsman 500 that it is hard to turn and has a significant amount of side to side play in the handlebars. I can see movement in the lower bushing and around the rivets. I have looked around and a lot of people have replaced the stock setup with a HPD bushing kit. How do I contact them to order a kit? I have done a google search and nothing came up and all of the links that have been posted don't work. Also I have read that I should try and grease the upper bushing but can't find the zerk. Thanks
Old Apr 4, 2015 | 06:58 PM
If you still have the old plastic steering block and rivets,you probably have a 2000 model(or early 2001) as for the 2001 model they show the updated steering block with the bearing and updated heavier steering post.If you can't find the sturdier set you're looking for you can up grade to the new steering post,bearing flange and bearing for not too awful much $. Items #4,8,9 on the parts break down.Just an another option on the table for you,plus we never had a problem with these like we had with the old plastic block and rivets coming loose. Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse
Old Apr 4, 2015 | 08:53 PM
Ok thanks. It could be a late 2000 or early 2001. I do have the black plastic with the rivets. I found one that speedwerx sells for $72 but that seems a little high for a bushing. Has anybody used one of these and how did it work?
buddieboy
Dec 9, 2016 05:50 PM
exmotocrosser
Sep 26, 2015 08:18 AM
woodthings
Sep 25, 2015 05:58 PM
Sw00p
Sep 24, 2015 02:50 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
