Honda trx450r
Old 06-10-2016, 09:48 PM
Viper21's Avatar
Default Honda trx450r
I bought a used atv honda 2004 trx450r and it idles rough and the exhaust gets red hot. I took apart carb and cleaned with carb cleaner but still runs rough, it has 87 octane gas in it as well. There is a black know which i think is for idle and when i turn it the idle changes but is still rough and when i hit throttle it backfires and u can even see flame out exhaust, any help guys?
Old 06-11-2016, 07:37 AM
Scooter86's Avatar
Knows Old ATV Questions!
It is running lean. Did you pull the pilot and verify it was free of debris? If so you should go up a size or 2 and see if that helps. Also, you need to use premium in these. 91 octane as they have to much compression to run 87 reliably.
Old 06-11-2016, 07:54 AM
Viper21's Avatar
What do you mean pilot, I am new to this so may need a bit more direction. I assume you mean the jets go up a size or two? I can put the higher octane in and see if that helps as well.
Old 06-11-2016, 10:21 AM
Scooter86's Avatar
The higher octane won't cure your issue, but is necessary. You could also have an exhaust or head gasket leak potentially. The pilot is a jet, accessed through the float bowl. It is responsible for fuel delivery up to approximately 1/4 throttle. The opening is small and one of the first places to gum up and clog on a machine that has sat with fuel in it.
grapejuice420
10-26-2017 06:48 PM
hawkdude
19
04-04-2016 07:38 AM
Fasteratv
04-01-2016 12:01 PM
danger2nature
2) Chassis problems..
03-22-2016 09:43 AM
stihlman
03-20-2016 10:28 PM
Quick Reply: Honda trx450r
