1999 Polaris magnum issues
Old Jun 15, 2016 | 11:15 PM
SheilaDarling's Avatar
Default 1999 Polaris magnum issues
My quad won't move unless it's in 4wd. Starts fine but when I put it in gear nothing. No movement at all. I can put it in 4 high and it will go. Any ideas?
Old Jun 16, 2016 | 07:35 AM
Sounds like the coupler connecting the rear prop shaft to the rear differential is stripped out not allowing the rear drive to engage. Had several come into the shop like this. Easily overlooked in this box frame and many people don't realize it's there or if they do,don't realize it has a grease fitting.Item #17 in the parts break down.Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse A lot of work to get to this coupler as the rear diff and axle have to be removed.
Old Jun 16, 2016 | 11:10 AM
Alex G.'s Avatar
does the prop (drive) shaft turn?
Old Jun 16, 2016 | 02:12 PM
If it's like the ones I got a hold of the prop shaft from the gear case would turn,but not the rear diff pinion or rear axle if the coupler splines are stripped out.
Old Jun 17, 2016 | 10:30 AM
Alex G.'s Avatar
OPT.... I guess I should have been a bit more specific...I was asking sheiladarling.. I kinda knew what you were saying, just wanted to know if sd saw what you were explaining...
Old Jun 17, 2016 | 12:41 PM
Sorry if I stepped on any ones toes.. We'll just wait on SheilaDarling to post back. Some people do,some people you never hear from them again..
m2cyclone
May 8, 2016 10:37 AM
scottaruth
May 1, 2016 01:00 AM
susukiquad
Apr 20, 2016 10:36 PM
Deerhunter96
Apr 10, 2016 01:32 PM
LostKeyboard
Apr 10, 2016 10:24 AM
