Old Sep 11, 2016 | 07:46 PM
Chris Wisdom's Avatar
Default ???
can anybody tell me if I have a bad rev limiter will it cause a four wheeler not to start? when it does start it runs good for like 5 mins then it just quits like it's not getting no gas but after I sit their for a couple mins it will start bak sometimes! can anyone help me with this priblem
Old Sep 11, 2016 | 07:53 PM
HawkeyeRider's Avatar
Sounds like a clogged fuel filter, or float in carb not dropping to let fuel flow properly into bowl.
Old Sep 11, 2016 | 08:02 PM
Default ok
so u dnt think it would have nothin to do with my rev limiter?? and Idk how it could be my float bc I've put all new guts in the carb everything is new.. but I haven't checked the fuel filter yet but idk if thats it either bc it will start and run for a couple mins then quit and is hard as hell to start bak
Old Sep 11, 2016 | 10:14 PM
user493's Avatar
Moto Psycho
What year and model? It might make a difference.
Old Sep 12, 2016 | 05:50 PM
hydrex's Avatar
Both of my Arctic Cats will run out of gas when the tank still has a couple gallons, if I forget to switch to reserve. Just a thought, first time almost drove me nuts, opened the fill, hmm, looks half full, finally switched to reserve, bingo! Also check gas tank vent for being plugged. Mud dauber wasps like to plug mine up with mud.
Old Sep 13, 2016 | 09:38 AM
Zrock's Avatar
Super Quad Patrol
If the float was not adjusted properly their will not be enough fuel in the bowl to continue running. I have also seen the fuel shut off go bad, main side of valve plugs up and will only work properly off reserv side.
If its not a fuel issue it could be something overheating as well. Mechanical or electrical
tedcyg
1) Engine problems..
11
May 2, 2019 04:36 PM
Cameront23
Sep 12, 2016 09:26 PM
Robertr48
Sep 6, 2016 03:26 PM
Thejuice51
Technical and How-To Articles
Aug 29, 2016 11:57 AM
rcappie4
Aug 27, 2016 06:09 PM
