tao tao 110cc ATV issues...
Old Sep 13, 2016 | 03:04 AM
Robin Buddi's Avatar
Default tao tao 110cc ATV issues...
Hello all! I have a Tao Tao 110cc ATV with a few issues.
The metal bracket that mounts rear of engine to frame has a crack going all the way across. Was causing chain to come off and needs to be welded. Now, it can be welded BUT I wonder if there is any kind of modification that can be done to prevent it from re-occurring??
2) I need to know what battery this ATV calls for. WalMart p/n? This 110cc ATV never had one and jumping solenoid is a pain in the rump.
3) The front wheels go out of adjustment frequently. The adjuster has nuts for locking but don't ever stay tightened.
4) I have the headlamp but it can't be mounted because the body mounting clips are broken off. Any ideas on repairing this issue?
Please advise. Any/all help given would be much appreciated. Thanks a million!!
Old Sep 13, 2016 | 11:37 AM
DirtDevil101's Avatar
Need a pic of the metal bracket with the crack...good pics on the machine are best...post that and I can provide welding advice...
Old Mar 25, 2021 | 08:34 AM
Scb1712's Avatar
My Tao 110cc came with a Genesis NP5-12v 5a battery. Just double check the size of your connectors as they’re available with either F1 (3/16) or F2 (1/4) tabs.
as for the front wheels, you could try replacing the locking nuts with nylon insert nut
Old Mar 25, 2021 | 09:39 AM
Zrock's Avatar
Super Quad Patrol
Put some loctight on the lock nuts and tighten them good
Booker140
1) Engine problems..
Oct 14, 2019 10:48 AM
Deyles01
Ask the Editor
Oct 9, 2017 04:21 AM
