Front axle 2003 Polaris Sportsman
Old 06-16-2017, 03:04 PM
Doug Labat's Avatar
Default Front axle 2003 Polaris Sportsman
Replace my CV boot on my front axle of a 2003 Polaris 500 Sportsman. Had to replace the a arm as well and now it won't fit together, my front axle won't go all the way in doesn't seem as if my front axle is all the way in what should I do?
Old 06-16-2017, 03:38 PM
Check that the cv is seated all the way on the shaft circlip. Easy way to tell is pull on the cv joint and it shouldn't move from the shaft if the circlip is locked in place properly in the cv joint groove.
Attached Thumbnails Front axle 2003 Polaris Sportsman-f23173b697548efdb07f2747437b18717e914866.png
Old 06-16-2017, 07:36 PM
Doug Labat's Avatar
the CV boot is on the shaft I had to replace my a arm it seems as if the axle is not all the way
in because my arm is not bolting up.
Old 06-17-2017, 05:08 AM
Why is the a-arm not bolting up? Tabs bent,not lining up from a wreck?
