Electric start bypass
Old Jul 4, 2017 | 03:52 PM
Gabriell1229's Avatar
Default Electric start bypass
I have a 2001 polaris trailboss 325 and the electric start switch stopped working I'm wondering what else I can do to startI have a 2001 trailboss 325 and the electric start switch stopped working I'm wondering what else I can do to start it temporarily (pull start broke too) I've tried jumping the solenoid but I think the switch broke in the off position so I'm wondering if there's something I can do just to be able to ride until I can afford the new switch it temporarily (pull start broke too) I've tried jumping the solenoid but I think the switch broke in the off position so I'm wondering if there's something I can do just to be able to ride until I can afford the new switch. I have a simple on off switch
Old Jul 4, 2017 | 04:01 PM
7 bucks with free shipping on an ignition switch.Can't get much cheaper than that.IGNITION KEY SWITCH FITS POLARIS TRAIL BOSS 325 SE 2000 2001 ATV NEW | eBay Don't advise it but you can use a jumper wire or paper clip at the red and red/black wires of the switch harness as a temporary bypass. Then you should be able to use the start button. Have to remember to pull the jumper wire when through riding.
Old Jul 4, 2017 | 04:14 PM
I must've got the part wrong the problem is with the switch on the handle bar I think it was in kill mode before the switch broke and I can't start it i have the key is just won't start because of the switch
Old Jul 4, 2017 | 04:54 PM
If you can disconnect the black kill wire(without cutting up the harness) and jump the red to red/black.This should bypass the left control switch and allow power to the ignition switch. Don't know if this works but worth a try.
Old Jul 4, 2017 | 04:58 PM
I'm gonna see if this works thank you ill let you know.
Old Jul 4, 2017 | 05:04 PM
You are talking about the wires running to the handle bar switch right?
Old Jul 4, 2017 | 07:38 PM
Yes..
Old Jul 5, 2017 | 10:51 PM
Bigdhotshot's Avatar
Yes..
I have an 04 sportsman 700 that I want to bypass the original ignition switch. I got the wiring diagram from my polaris dealer and it only shows 7 wires going to the switch but I have 10 wires! I want to put a toggle switch to power up everything and a momentary switch for the starter. Is this possible? If so, which wires do I put to the toggle and which wires to the momentary?
Old Jul 6, 2017 | 05:31 AM
Same thing I replied to in your other post.. Why? If it's a switch problem this 3 position switch is cheap.10 bucks.http://www.ebay.com/itm/IGNITION-KEY...5YLwwM&vxp=mtr
Old Jul 6, 2017 | 06:54 AM
scootergptx's Avatar
Supersock
Hired Gun!
I'd spend the 10 bucks. Down the road you may want to sell these. Would you buy an atv that the ignition has been hotwired?
Also, you could be out on a public trail somewhere and might just have a courtesy check from either law enforcement or game warden. That is going to look very suspicious to them.
