Difference between a 2004 and a 2005 Polaris Sportsman 500 h.o.
Old 01-26-2019, 07:21 PM
jphillips89's Avatar
Default Difference between a 2004 and a 2005 Polaris Sportsman 500 h.o.
I have a 2004 Polaris Sportsman 500 h.o. And i put forward a-arms on it the forward a-arms are cor a 2005 bc they don’t make them for the older years what is the difference between the two because i am having a problem with them being about 2” longer and messing my tire angle up.
Old 01-26-2019, 10:00 PM
Big Frank's Avatar
THE BERMINATOR
I know they changed some things from 2004 - 2004.5 - 2005 but I never knew what they were. Hopefully someone else does. Good luck.
Old 01-27-2019, 07:03 AM
Specta's Avatar
I'd ask this in the Polaris ATV section. You might get a better response.
Old 01-27-2019, 10:34 AM
Zrock's Avatar
Super Quad Patrol
They probably made it a inch or 2 wider on 05. You can probably make it work but you will have to lower your shocks to compensate for the difference as well as do something about the axles and the rear of the machine. What was wrong with the old a arms
Quick Reply: Difference between a 2004 and a 2005 Polaris Sportsman 500 h.o.
