How do i tune a Pz27 Carburetor
![](https://cimg5.ibsrv.net/gimg/atvconnection.com-vbulletin/790x505/r_a2bce9cb84b94e25f223f51557a681c9b3bd1dce.jpg)
Number 13 in the picture. The fuel mixture above idle is controlled by the slide and main jet which is inside the bowl of the carb.
What kind of problems are you having? Every time I have worked on a chinese carb the main jet and air jet if equipped are too small and you need to take them out of the old carb, or buy new, or drill them out to the proper size.
If i understand correctly the main jet is for wide open throttle and the slide needle adjustments are more for mid range stuff.
![Post](https://atvconnection.com/forums/images/icons/icon1.gif)
So what is number 26? what does it do?
Rob4092
11
08-14-2000 05:44 PM
Rob4092
07-25-2000 08:02 PM
