twister hammerhead 150cc go off road go kart
#622
sorry to change the subject
hi there names david from melbourne australia.
recently purchased a twister hammerhead 2005 model for about $2500 australian. i have read through the forums and agree with some of the comments regarding the carts power. It is a bit dissapointing and recently have been looking at a replacment engine preferrable an automatic. say about a 300cc. hoping an atv engine could fit without too many headaches. has anyone attempted anything like this?? if its impossible for an engine change how else can i get some more power out of a 150cc motor. other than the exhaust. i found 2 sites check these out
www.turbonator.com or
www.tornadoair.com
anyone used these parts? would they work on a twister? is this possible?
although i reckon the cart is well built, jumps well, and good fun but that extra 100cc would be perfect....
www.tornadoair.com
#623
www.tornadoair.com
www.tornadoair.com
#624
Or just do what several others I've run across have done, and gut the pipe for more flow... add the higher jetting, and get the UNI filter... Good results and very cheap.
-Steve
-Steve
#625
thats the 1 thing i really dont understand. higher jetting. and gutting the pipe. ive read through the forum (took about 2 hours) and couldnt get any detailed explination. thanks raptoraz and hopsterguy
#627
just brought a pod filter for my twister. should i remove the air box completely and run the ducting straight to the carby with the pod on the end.
or just remove the stock air filter and put the pod on the end of the duct.
which would work better
thanks
thanks
#628
I've seen both done. Better air flow if you remove everything totally. People have found muffler extentions at car shops that fit about right and then weld a little arm on it so it can bolt right up to the existing frame mount.
thanks
thanks
#629
cool thanks for your help
the other thing i really dont understand. higher jetting. and gutting the pipe. ive read through the forum (took about 2 hours) and couldnt get any detailed explination. can i mod the exhaust without buying a new one from the states being from australia and all.
#630
Does anyone know if the Titan II 250cc Kart is any good? I keep waiting for Twister to come out with their 250cc model but have not seen any mention of it in a while. Thanks
