How to install temp. gage on a Rhino
Old May 26, 2006 | 10:17 AM
RIS's Avatar
RIS
Default How to install temp. gage on a Rhino
Can someone please tell me step by step how to install a temperature gage on a Rhino & who sell the best kit?
THANKS!
Old May 26, 2006 | 12:21 PM
RIS's Avatar
RIS
Sorry about the miss spell on "gauge"
THANKS!
Old Jun 1, 2006 | 02:26 PM
RIS's Avatar
RIS
I got a kit from High Lifter. The gauge and all I need to hook it up for $85.00
Old Jun 11, 2006 | 07:58 PM
jim4065's Avatar
I'd like to know how it works out and how easy it was to install. Considering the BRP faceplate and some gauges.
Old Jun 14, 2006 | 02:17 PM
RIS's Avatar
RIS
I haven't installed it yet (been messing with my boat) but It shouldn't be a problem. The kit I have, you cut a radiator hose and install the temp pick up unit in line. I'm going in the hose out of the radiator to the eng. I'll mount my gauge just above the cup holder I added. That and 12V. should do it.
Old Jul 19, 2006 | 07:03 PM
TriSum's Avatar
It's not really difficult. I've installed them on the drivers side of the motor in the coolant hose. It should come with an adapter to screw the temp sensor into. Cut a section of the hose out and put the adapter in (Be sure and use a couple pair of vise grips on the out side of where you are going to cut the hose. This will keep the coolant from running out.) Put the hose clamps on, run the power and ground and mount the gauge. It is not hard but can get messy if your not sure what you are doing.
ReconBayou
Oct 31, 2022 05:37 PM
2many2ride
Sep 27, 2015 04:35 AM
Halffast17
Sep 11, 2015 02:30 PM
toonces
Sep 5, 2015 01:14 PM
