rhino trouble
Old Jul 9, 2006 | 04:51 PM
ncrustler's Avatar
Default rhino trouble
Hi everyone I just got my new rhino 450 last month in june and I found a vary hard vibration just after you start moving at the speed of about a fast walk the place where I got it at is trying to blame it on tires but the vibration is just to hard after you get a bit faster you can feel the tires then. I have taken it back to them and now thay tell me that thay have a new 650 back with baaring problems and that mine has the same actions as the 650. Has anyone else had the same problem.
Thanks for any advice on this
Old Jul 10, 2006 | 01:09 AM
yellowrider250ex's Avatar
our's vibrates for just a little bit at about that same speed but its quiet after that and its a 660
Old Jul 12, 2006 | 05:10 PM
ncrustler's Avatar
Hi again just letting everyone know that I called the dealer about my rhino 450 and he told me that a rep for Yamaha was suppose to be there to check out the broken 660 and my 450 this week some time Hope I have not brought a lemon so far I have found another 660 with bad bearings in the frunt gear box and that is where mine felt like the vibration was coming from I will keepeveryone poasted on my adventure haha
thanks
Old Jan 18, 2007 | 02:37 PM
Oldquaddie's Avatar
I know it has been a while since you last posted. Did you figure out what the problem was? I just bought a 660 last week it it also vibrates pretty bad at a slow speed. The vibration seems to be coming from the transmission / CVT area. Seems to occur just after the drive pully starts to turn. I am not sure if this is normal because it seems fine once you get the speed up. Could also be because of it being a 660 sigle cylinder, and simply vibrates alot. Has anyone else had this problem?
Old Jan 18, 2007 | 08:26 PM
Slimegreencat's Avatar
Its totally normal , this has been discussed on numerous forums . everyones Rhino does it .
Pull your engine cover off , and then start it up and let it idle , then slowly start to depress the gas until you hit that sweet spot (vibe/rattle) you will find it just above idle . I have found it to be the cvt pipe that runs along the driver side of the engine , and also the belly pan rattles a bit too at the right rpm , heck , even the hood rattles a bit at certain rpm's .
It's annoying , but if you realize its normal and there is nothing to be concerned about , you will find it becomes less noticeable , after a while you wont even notice it
Happy Rhinoing
Old Jan 19, 2007 | 08:34 AM
Oldquaddie's Avatar
Thanks for thr reply. In the meantime, I took the drive belt off to determine if it was coming from the transmission. The vibration was still there. Does everyone have this vibration? I like to cruise slow ( also had it on 2 wheels while railing a berm, I ain't that old ) and the noise is just to much.
A word of warning....I must have turned the output shaft the wrong direction while reinstalling the belt and screwed up the sprag clutch ( one way gear ). It ended up galling the race on the centrifugal clucth and now wants to spin the output shaft all the time, not allowing it to go into gear. Thats what I get for being too curious.
I now need to replace the centrifugal clutch and one way bearing and I have only had it 5 days :-(
$400.00 and a little work should have me up and running. I could run without but I would have no engine braking, one of the reasons I bought it over the Ranger.
While I am whining....I was not very happy with this brand new Rhino. The vibration was a dissapointment. I also had to reinstall the tail lights because they were crooked, the gas tank was mounted so far forward that you could hardly get the cap off, I found a seat belt mounting bolt laying in the belly pan..wondering what else I might find after I have had it a few weeks?
If you all tell me this is normal stuff, maybe I will feel better and get used to it.
Old Jan 19, 2007 | 11:33 AM
LTZ's Avatar
LTZ
The Ranger has engine braking also.
Old Jan 19, 2007 | 12:23 PM
Oldquaddie's Avatar
I thought someone might catch me on that. I should have said 4 wheel engine braking.
95wolv
Sep 27, 2024 12:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
greg74
Sep 10, 2015 07:58 AM
