break-in period question
It's ready to be changed......I found a bit of engine shavings in my screen(separete than the drain plug) that were left over from machining the engine...best to get that chit out sooner the better...
bummer, the dealer is 36 miles away. I guess you are supposed to change the oil filter also, so it wouldn't do me any good to get some high quality oil from Autozone? or is there an alternative to Yamalube, or for that matter, an aftermarket oil filter that works?
Yes you can get an atv valvoline oil at some autozones or advanced auto stores....I have even found a filter at walmart that works in my 450......you may need to do some serching on here to fing parts #'s foe the filter...or start a new thread....
here is a web page with the oil I am telling you about....
www.valvoline.com/atv/
www.rockymountainatv.com/
www.rockymountainatv.com/vehicleSelectProd.do
You can get K&N oil filters with the check valve for about $8 and they come with a nut on the end for easy removal....they have oil and eveything else as well.....don't get the oem
I use Purolator oil filters along with a powerful filter magnet. Tested to be superior.
Purolator filter #PL14610 is the exact replacement. But a few millimeters longer, holds more. If you forget the number it fits first generation Miata's, so it's easy to remember. Same oil pressure bypass setting.
Synthetic oil is vastly superior to liquid dinosaur. It's made from the finest ingredients known to man.
Have seen cleanable screen type Rhino filters selling on ebay... pure trash...
the more you change your oil, the less your engine will ware. i douch my rhino every 10 to 13 hrs (if possiable). as far as break-in i would let the stock oil cut your motor for about 1 tank of gas then go to full syn.
if opinions were airplanes, this place would be an airport!
