Linhai 400
Old Aug 4, 2014 | 01:07 PM
ALCrawdad's Avatar
Default Linhai 400
I just purchased the 2014 Linhai Bighorn 400 and was looking through the owners manual as far as maintenance. The maintenance schedule is set by hours and I don't have hours indicated, as it is lists miles used instead on the panel. Anyone else had this issue on other SxS's?
Old Aug 5, 2014 | 09:48 AM
ALCrawdad's Avatar
Default Linhai 400
Duh, found the button on the display panel. Such a newbie.
Old Aug 5, 2014 | 10:54 AM
Jaster94's Avatar
too bad they "hide" the features you're looking for.....live and learn. glad you found it.
Old Aug 6, 2014 | 07:42 AM
ALCrawdad's Avatar
I am really pleased with this SxS, put it to the test last weekend. Wish it was not so loud though. Thinking I will keep ear protection in the glove box and wear these when riding. Don't know if there is an after market muffler I could have installed to soften the noise. I also installed a windshield on it. The dealer told me I might consider taking it off when towing on the interstate, but it was such a pain to put on, I don't think I will. Seems to be on there pretty good, so I don't see how it could come off,
Old Aug 6, 2014 | 03:35 PM
Jaster94's Avatar
there should be quieter mufflers on the market as far as decibel ratings. linhai is a yamaha clone so yamaha mufflers should interchange quite easily.
Old Aug 9, 2014 | 04:08 PM
ALCrawdad's Avatar
any ideas on adjusting the suspension? I rode a friends Rhino today and the ride was so much more comfortable. I wonder if this is something I can improve on the Linhai by either changing out the shocks or if adjusting? Any ideas?
Old Aug 9, 2014 | 05:15 PM
Jaster94's Avatar
try adjusting before changing out shock. now, your tires are at the correct pressure, right? they don't need to have 50 psig in them, only like 4-8 psig.
Old Aug 11, 2014 | 10:36 AM
ALCrawdad's Avatar
Default Adjusting suspension
I will check the tire pressure. I found out how to adjust the suspension and see the factory settings are in the middle, so will try to adjust it by one notch and see of this make a difference. This is on the rear. Did not see this type of adjustment possible on the front.
This is a video I found to do this:
Old Jan 18, 2021 | 03:01 AM
JASON1418's Avatar
Default Linhai 400cc bighorn 2d atv problem
Linhai 400 Bighorn 2D 2014model starts to sputter after about 6miles. Bought a new Carburetor and gave it a good service and still the same problem. I checked the following:
Spark
CDI
Regulator(charge 14 volt)
Coil
New battery
Fuses
Any help will be appreciated.
Michael Rose
Oct 1, 2013 10:58 PM
rickytz7111
May 18, 2004 08:18 AM
rickytz7111
Mar 31, 2004 03:57 PM
jmak
Mar 7, 2003 06:44 PM
