Do-It-Yourself Porting?
Old Jun 12, 2003 | 10:39 PM
yellowexracer's Avatar
Default Do-It-Yourself Porting?
I plan on adding either a Wiseco 11:1 or a JE 10.8:1 piston with hotcams stage 2 very soon and I am wondering if I would hurt anything if I cleaned up the casting marks on the intake and exhaust with a die grinder?
Are the marks that big?
What kind of power could I gain?
Old Jun 12, 2003 | 11:16 PM
smitty911's Avatar
If you plan on doing this yourself GO VERY SLOWLY. use sandpaper rolls to just smooth the flashing. Match your Carb Boot to the head as well. Leave the intake rough and polish the exhaust.
As far as power, I don't think you will get that much from the clean up. You should notice the higher comps though.
Smitty
Old Jun 12, 2003 | 11:35 PM
thanks, yea i don't want to mess anything up so i'm gunna go slow and do it right
Old Jun 13, 2003 | 12:23 AM
redranger1's Avatar
smitty911 is right on. one more thing you may want to consider is to clean up the valve guides inside the ports. nathan
franklyme
Oct 21, 2016 07:18 PM
QuadRiders
Oct 22, 2015 04:13 PM
Brandon400
Sep 5, 2015 08:44 PM
