350X Carb on a 300EX
Old Jul 6, 2003 | 03:32 AM
JakalWarrior's Avatar
Default 350X Carb on a 300EX
Ah, thought u said the 350x carb was 1 mm smaller than the 300ex one. Being 2 mm bigger will give it a boost on top end and make it make more power when you start modding it. No accelerator pump though means its wont react as fast when you mash the gas. Prolyl some other stuff too lol, but ive never had a machine without one.
Old Jul 6, 2003 | 03:19 PM
ride350x's Avatar
hey 1986atc250r
If i put that 400 ex carb on my 350x, will i have to mess with the jetting and other stufff. I was also wondering if i put a pipe on, would i have to jet it. Thanks
Old Jul 6, 2003 | 03:39 PM
1986atc250r's Avatar
Yes, jetting changes are required. It's not usually a big deal though.
Anytime you make changes that will alter the engine's air flow properties (i.e. practically anything you do), you'll need to make jetting changes to make the most of your modifications.
Another trick is to remove the choke plate on these carbs. Although it won't make a huge improvement, it does make a noticible throttle response difference. If memory serves me correctly, it's good for about a 1hp gain on a 400EX.
Old Jul 7, 2003 | 01:53 PM
TheQuadSport230's Avatar
Would it make any difference with a 400ex carb on? is it Worthing it go get one?
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
