400ex counter sprocket
Old May 16, 2000 | 05:57 PM
cmchonda's Avatar
Does anyone know if a 1997 to 2000 XR400 counter sprocket will work on a 1999 400 ex? I would like to go to a 14T but my local dealer said they are on back order. They do have a 14T for a XR400.
Old May 16, 2000 | 06:12 PM
426ex's Avatar
from what i been told they are identical
Old May 16, 2000 | 07:02 PM
bluedevil's Avatar
I just put a 14 tooth on my 400EX, and boy does it pull now. I have the WB rev box on it to, i would reccomend this so you can wind it up a little higher. I used to be able to get the front end up a little in third gear, now with 14 tooth i can get it staight up in third. Better response all through the powerband too!
Old May 16, 2000 | 11:53 PM
JAKOOL's Avatar
If ever you'll be using the XCT'S try it with a 13/39 combination you will love it too.
Old May 17, 2000 | 01:35 AM
Air's Avatar
Air
Yes they are the same.
99 426ex , Web Cam, FCR carb w/ twist, CT revlimiter, DMC exhaust, XCT's ,K&N, One kit, Renthal bars, DG nerfs, Armidillo Swingarm plate, 8 paddle Haulers
http://www.trxoutlawz.com/
Old May 17, 2000 | 02:00 AM
azrob's Avatar
Sprocket Specialists also sells several sprockets for the 400EX. I bought the 14 tooth sprocket ($21.00) and it greatly improves 2nd gear, not to mention pulling a wheelie while stopped in first gear.
Old May 17, 2000 | 09:53 AM
garyc400ex's Avatar
they are the Same! It's pretty sad that your local dealer does'nt know this.
Old May 17, 2000 | 11:28 AM
fasttrax's Avatar
I put a 14 tooth on my 400ex and was disapointed in the climbing. big sand mountains face I can climb with my 15 tooth but not my 14. this could be also the paddles (20" 7 paddle skattrak) since I spin all the way up. any ideas appreciated.
Old May 17, 2000 | 11:36 AM
garyc400ex's Avatar
I would check with "AIR" concerning sand dunes and your 400ex.
Johnny Mac
Aug 15, 2019 03:13 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
