hotcam electrical prob?
Old Jul 12, 2003 | 03:09 AM
thor440's Avatar
Default hotcam electrical prob?
440, port & polish, full exhaust, wb rev kit and just installed stage II hotcam. I burned a fuse. When my rpm's get higher, my lights flicker. I think I still have more rev to go too. None of this happened until I installed the cam. I've tightened the valves tighter(exhaust) than the recs are and they still knock. Whats your opinions?
Old Jul 12, 2003 | 12:06 PM
thor440's Avatar
Cmon, any suggestions. Too much power generated from the high rpm's causing the fuse to blow? How do I fix this. Or is the rev limiter peaking causing the lights to flicker and how to fix that problem. Any valve adjustment ideas besides keep tightening. Seems like its a pain in the butt to bend that guage down in under. Is there other types of guages.
Old Jul 13, 2003 | 12:15 AM
moto93's Avatar
The cam doesn't have anything to do with the blown fuse, it's probably the rev box that's giving you problems. I have the same cam as you and I'm running it at .006-.007 clearance. You're never going to totally get rid of the valve train noise and you're asking for trouble if you tighten them down too much.
Old Jul 22, 2003 | 01:24 AM
witti's Avatar
how do you like your cams, is there a big improvement?
my friend is thinking about geting one.
Old Jul 22, 2003 | 01:19 PM
yellowexracer's Avatar
What stage are the cams?
Old Jul 23, 2003 | 01:25 AM
witti's Avatar
yellowexracer were you asking me ?
stage two
ReconBayou
Oct 31, 2022 05:37 PM
EIF
Apr 20, 2017 07:15 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Sw00p
Sep 24, 2015 02:50 PM
